WordPerfect Graphic (WPG)
The Corel WordPerfect Graphic file format (WPG) is primarily a vector graphic format, but it can store both bitmap and vector data. The WPG files may contain up to 256 colors, chosen from a palette of more than 1 million colors.
To import a WordPerfect Graphic file
Back to Top
1 Click File Import.
The File Import command lets you place the file as an object in the active image. If you want to open the file as an image, click File Open.
2 Locate the folder in which the file is stored.
3 Choose WPG - Corel WordPerfect Graphic (*.wpg) from the list box next to the File name box.
4 Click the filename.
5 Click Import.
6 Click the image window.
WordPerfect Graphic (WPG) technical notes
Back to Top
Graphics Text Type 2 is not supported.
