Align and distribute objects
You can align an object to image elements, or distribute objects throughout an image.
Objects can be aligned to each other, to the center of the image, to the edge of the image, or to the grid and guidelines.
You can also align objects interactively by using alignment guides. For more information, see Alignment guides.
Distributing objects automatically adds spacing between them based on their width, height, and center points. You can distribute objects so that their center points or selected edges (for example, top or right) appear at equal intervals. You can also distribute objects so that there is equal space between them. You can distribute objects within the bounding box that surrounds them or over the entire image. In addition, you can distribute objects by specifying the distance between them. Objects can be distributed vertically, horizontally, or both.
You can access some of the alignment commands directly from the Object
Align and Distribute menu, and you can access all alignment and distribute options from the Align and Distribute inspector (Object
Align and Distribute).
To align objects
Click
Object
Align and Distribute.
In the
Align to area of the
Align and Distribute inspector, choose a reference point by performing a task from the following table:
Align an object with a specific object
Click the Selected objects button  .
If you select the objects one at a time, the last object selected is the reference point for aligning the other objects. If you marquee select the objects, the object that is positioned in the upper-left corner of the selection is used as a reference point.
Align an object with the document edge
Click the Document edge button  .
Align an object with the document center
Click the Document center button  .
Align an object with the closest grid line
Click the Grid button  .
4
Click one of the following buttons to use an object edge or center for aligning.
Align left
— to align the left edges of objects
Align center horizontally
— to align object centers along a vertical axis
Align right
— to align the right edges of objects
Align top
— to align the top edges of objects
Align center vertically
— to align object centers along a horizontal axis
Align bottom
— to align the bottom edges of objects
To distribute objects
Click
Object
To choose the area over which the objects are distributed, click one of the following buttons in the
Distribute to area of the
Align and Distribute inspector:
Selected objects
— distributes the objects over the area of the bounding box surrounding them
Document edge
— distributes the objects over the entire document
4
To distribute objects horizontally, click one of the following buttons:
Distribute left
— evenly spaces the left edges of the objects
Distribute center horizontally
— evenly spaces the center points of the objects along a horizontal axis
Distribute right
— evenly spaces the right edges of the objects
Distribute space horizontally
— places equal intervals between the objects along a horizontal axis
5
To distribute objects vertically, click one of the following buttons:
Distribute top
— evenly spaces the top edges of the objects
Distribute center vertically
— evenly spaces the center points of the objects along a vertical axis
Distribute bottom
— evenly spaces the bottom edges of the objects
Distribute space vertically
— places equal intervals between the objects along a vertical axis
To distribute objects, you must have more that one object selected.
To distribute objects by a specified distance
Click
Object
In the
Align and Distribute inspector, click the
Object spacing button
4
Type values in the
H and
V boxes.
5
To distribute objects horizontally, click any of the horizontal distribution buttons.
6
To distribute objects vertically, click any of the vertical distribution buttons.
