Combine lenses with the image background
To apply a lens adjustment and special effects to the pixels of an image, you combine the lens with the image background. Combining a lens with the image background reduces the file size of the image and lets you save the image to a non-native file format. If you save an image as a Corel PHOTO-PAINT file, lenses are saved with the image and do not have to be combined. Once a lens is combined with the image background, the lens cannot be selected or modified.
When you combine a lens with the image background, you can choose a merge mode to enhance the results. For information about merge modes, see Merge modes.
To combine a lens with the image background
Back to Top
1 Click the Pick tool .
2 Select a lens.
3 In the Objects inspector, choose a merge mode from the Merge mode list box.
If the Objects inspector is not open, click Window Inspectors Objects.
4 Click Object Combine, and click one of the following:
Combine objects with background — combines the selected lens with the image background
Combine all objects with background — combines the selected lens and all other objects with the image background
