Place (import) files
Corel PHOTO-PAINT provides filters that convert files from one format to another when you place them. You can import a file and place it in the active application window as an object. The imported file becomes part of the active image.
You can search for images by different criteria, such as filename, title, subject, author, keyword, comment, and other properties attached to the file.
You can also export Corel PHOTO-PAINT images to a variety of file formats. The file format that you choose depends on how you want to use the image in the future. For more information about exporting files, see Export images.
To place a file into an active image
Back to Top
1 Click File Place.
2 Locate the folder where the file is stored.
3 Click a filename.
If the file contains text in a language different from the language of your operating system, choose the corresponding option from the Code page list box to ensure that notes and object names are displayed correctly. This option is not available for all file formats.
4 Click Import.
5 Click the image window.
You can also
Use the filter’s default settings without opening its dialog box
Click Options, and enable the Hide import filter dialog check box.
Search for an image
Type a word or phrase in the search box.
The search box looks for files only in the current folder and subfolders. To search for an image in another location, you must first navigate to the folder where the image is stored.
