Remove dust and scratch marks
Corel PHOTO-PAINT provides several different ways to improve the appearance of an image that has small dust and scratch marks. You can apply a filter to the entire image, or if an image has one or more scratches in a specific area, you can create a mask around the scratches and apply the filter to the editable areas.
The filter works by eliminating the contrast between pixels that exceed the contrast threshold you set. You can set a radius to determine how many pixels are affected by the changes. The settings you choose depend on the size of the blemish and the area surrounding it. For example, if you have a white scratch that is 1 or 2 pixels wide on a dark background, you can set a radius of 2 or 3 pixels and set the contrast threshold higher than if the same scratch were on a light background.
You can also remove imperfections, such as tears, scratch marks, and wrinkles, from an image by blending its textures and colors. Similar to using a filter, you choose the range of pixels necessary to retouch the image, depending on the size of the correction and the area surrounding it.
If the scratch or blemish is fairly large or in an area of the image that has a varied color and texture, such as leaves on a tree, you can achieve better results by cloning image areas. For information about cloning, see Clone image areas.
To remove small dust and scratch marks throughout an image
Back to Top
1 Click Image Correction Dust and Scratch.
2 Move the following sliders:
Radius — lets you set the range of pixels used to produce the effect. Set the radius as low as possible to retain image detail.
Threshold — lets you set the amount of noise reduction. Set the threshold as high as possible to retain image detail.
You can remove small dust and scratch marks from an image by applying the Dust and scratch filter.
To remove scratch marks from part of an image
Back to Top
1 Define an editable area that includes the scratch marks.
2 Click Image Correction Dust and Scratch.
3 Move the following sliders:
You can remove a scratch from a specific area by surrounding the scratch with a mask before applying the Dust and scratch filter. A dashed line or red-tinted overlay indicates the presence of a mask.
You can use the Brush Mask tool to define an editable area that includes the scratch mark. Choose a nib size that is wider than the scratch mark so you can brush over the scratch easily. For information about the Brush Mask tool, see To define an editable area by using the Freehand Mask tool.
Feathering the edge of the editable area can improve results by softening the transition between the repaired areas and the original image. For information about feathering, see To feather the edges of an object.
To remove imperfections from an image by blending textures and colors
Back to Top
1 In the toolbox, click the Touch-up Brush tool .
2 Choose a nib from the Nib shape picker.
3 Type a value in the Nib size box to specify the nib size.
4 Choose an option from the Strength list box to set the intensity of the effect.
5 Dab the brush in the image window to apply the effect.
You can remove imperfections from an image by blending textures and colors with the Touch-up brush tool.
You can also
Apply the effect to the object and the background simultaneously
Click the Merged source button on the property bar.
Change the brush size
Hold down Shift while dragging in the image window. Release the key when the nib is the size you want.
Adjust the transparency of the brushstroke
Hold down Option, and click in the image window without releasing the mouse button to display a transparency slider.
Adjust the feathering of the brushstroke
Hold down Command + Option, and click in the image window without releasing the mouse button to display a feathering slider.
Use the pressure of a digital pen to control the amount of the effect
Click the Pen pressure button on the property bar.
You can use the Touch-up Brush tool on images in the grayscale, duotone, Lab, RGB, and CMYK color modes.
You can quickly choose a square or round brush shape by clicking the Round nib button or the Square nib button on the property bar.
