You can assign any of 50 icons to a script, and then drag the icon to a custom or existing toolbar, or to a menu. By dragging the icon onto a toolbar or menu you can have easier, quicker access to your favorite scripts, and can execute them with a single click.
You can use an icon for any number of scripts. For example, you could assign a red light bulb icon
to a script and drag it to the Photo toolbar. You could then assign the same icon to a different script and drag it to the Adjust menu.
The process of assigning an icon to a script is called "binding". After the script is bound, you can assign a keyboard shortcut to it as another way to execute the script. For more information about using shortcuts, see Customizing keyboard shortcuts.
Edit workspace
Choose View Customize to display the Customize dialog box. |
When you position the cursor over the toolbar’s script icon, you’ll see the path name and file name associated with the script. If you drag the script icon into a menu, the menu displays the script’s name, and the script’s path appears in the status bar.
Edit workspace
When you unbind a script from an icon, you also remove it from the user interface and from any keyboard shortcut assigned to it.
Edit workspace
