The table below describes each of the blend modes.
| To set the blend range of a layer |
| 1 | On the Layers palette, double-click the layer to open the Layer Properties dialog box. |
| 2 | Click the Blend Ranges tab. |
| 3 | In the Blend Channel drop-list, select a channel to use when blending layers. |
| Select Grey Channel to base opacity on the lightness values of layers. Select Red Channel, Green Channel, or Blue Channel to base opacity on the respective color values. |
| 4 | Drag the upper arrows to set the values at which the opacity is 100 percent. |
| For example, you can set a layer’s opacity at 100 percent between the lightness values of 43 and 126, with the opacity falling off at the lightest and darkest areas. |
| 5 | Drag the lower arrows to set the values at which the opacity is 0 percent. |
| 6 | Click OK. |
