You can edit vector text by converting it to curves and then adding, deleting, and moving nodes. Nodes are the tiny squares that appear along the object’s outline.
You can convert letters to individual curve objects, or you can convert the entire string of text into one curve object, with each letter as a separate contour within the object path.
Edit workspace
If you convert each letter to a separate vector object, you must select the letters individually in order to edit the nodes.
You can edit a curve object by using the Pen tool
in Edit mode. For more information, see Adding and closing contours.
