You can create your own effects (or filters), which you can save and reuse.
| To create your own effects |
| 1 | Choose Effects |
| The User Defined Filter dialog box appears. |
| 2 | In the Load Preset drop-list, select a filter to use as a starting point. |
| 3 | In the Filter matrix group box, type or set values in the controls to modify the coefficients that process pixels to create the effect. |
| 4 | Click OK. |
| Corel PaintShop Pro applies the effect to the image. |
Click the Randomize Parameters button
Click the Save Preset button
In the Load Preset drop-list, select the user-defined effect.
