To create image rollovers |
1 | Create the image to be used as the rollover image. Often this second image is a duplicate of the original, but modified to appear differently when the mouse rolls over the original image. |
2 | Do one of the following: |
• | Choose File ![]() ![]() |
Note: If necessary, navigate to an image region, and use the appropriate tool (for example, the Polygon, Rectangle, or Circle tool) to specify the region where you want to add a rollover. |
3 | Click Rollover Creator. |
The Rollover Creator dialog box appears. |
4 | Mark any of the following check boxes to determine which actions activate the rollover: |
• | Mouse over |
• | Mouse out |
• | Mouse click |
• | Mouse double-click |
• | Mouse up |
• | Mouse down |
5 | Click the Open button ![]() |
The Select Rollover dialog box appears. |
6 | Navigate to and select the graphics file you want to use. |
If you do not select a file, then the original file is used. |
7 | Click Open. |
In the Rollover Creator dialog box, the file path appears in the box beside the check box. |
8 | Click Cancel to return to the Image Mapper or Image Slicer dialog box. |
You can view your work in a Web browser window by clicking the Preview in browser button .
