| To add images to a layout |
| 1 | Open the image that you want to print. |
| If you want to select more than one file, hold down Ctrl, and click the files. If the files are in sequential order, click the first file, and then press Shift and click the last file. |
| 2 | Choose File |
| Thumbnails of the selected images appear on the left side of the window; the page layout appears in the main workspace. |
| If you want to add additional images to the Print Layout window, choose File |
| 3 | Drag the thumbnails into a template cell or onto the custom layout page. |
Click the Print button
Choose File
Click the Close Print Layout button
| To position images in a layout |
| 1 | In the Print Layout window, choose a cell. |
| 2 | Click one of the following buttons: |
| • | Fill Template with Image |
| • | Free Format |
| • | Size and Center |
| • | Fill Cell with Image |
| • | Fit and Center |
| • | Make Cell Elliptical |
| • | Make Cell Rectangular |
You can display the grid if you want to position images with precision.
| To rotate an image in a layout |
| 1 | In the Print Layout window, select an image. |
| If you want to rotate multiple images, hold down Shift, and select the images. |
| 2 | On the toolbar, click one of the following buttons: |
| • | Rotate Right |
| • | Rotate Left |
| To zoom |
Click the Zoom In 10% button
Click the Zoom Out 10% button
Click the Zoom Rectangle button
Click the Zoom to Page button
| To create a caption |
| 1 | Choose File |
| Thumbnails of the open images appear on the left side of the window; the page layout appears in the print layout workspace. |
| 2 | Drag the thumbnails into a template cell or onto the custom layout page. |
| 3 | Click the Create a Text Field button |
| 4 | Drag to create the text box. |
| 5 | In the Text Field dialog box, type the text that you want to appear on the printed page. |
| 6 | Set the font, font attribute, and alignment controls. |
| Note: To continue to use these settings, mark the Retain text settings check box. |
| 7 | Click OK. |
Right-click the text box, and choose Rotate Right or Rotate Left.
| To undo or redo a change to a layout |
| • | Choose Edit |
| To change the Print Layout workspace |
| 1 | In the Print Layout window, choose View |
| The Print Layout Options dialog box appears. |
| 2 | Choose a unit of measurement from the Units drop-list. |
| 3 | In the Auto Arrange group box, mark one or both of the following check boxes: |
| • | Use borders — creates a border around all images. This option requires you to set values in the Horizontal border size and Vertical border size controls. |
| • | Stretch to fit — automatically enlarges images to fit, while maintaining their aspect ratios |
| 4 | In the Template options group box, do one or both of the following: |
| • | To apply the new default placement option to all cells of the current template, mark the Apply to current template check box. |
| • | To specify the default placement of images in template cells, choose an option from the Default Placement drop-list. |
| 5 | In the Grid Settings group box, mark any of the following check boxes: |
| • | Show Grid — displays the grid |
| • | Snap-to-Grid — snaps images to the gridlines where you position them |
| If you marked the Show Grid check box, you can also mark the Dot Grid check box to use a dotted-line grid. Clear the check box to use a solid-line grid. |
| 6 | Click OK. |
Click the Grid color area, and choose a color from the color palette.
Set values in the Horizontal Spacing and Vertical Spacing controls.
