You can create a mask from an image by loading the image file from disk. When you use an image as a mask for another image, Corel PaintShop Pro applies the mask as a grayscale image. The source image is not altered. You can also create a mask by customizing one of the sample masks included with Corel PaintShop Pro.
An example of an image used as a mask
You can use a selection to create a mask that shows or hides the selection. You can use this mask as a starting point for creating artistic effects.
An example of a selection used as a mask
You can also create a mask from a channel by first splitting an image into its RGB, HSL, or CMYK channels. Corel PaintShop Pro creates a grayscale image for each channel. You can use one of these channel images to create a mask for the original image or for another image.
An example of the grayscale channel used as a mask
Edit workspace
Choose Layers New Mask Layer, and choose one of the following options: |
Show All — shows all underlying pixels |
Hide All — hides all underlying pixels |
Choose View Palettes Overview.
You can paint on the image to show portions of the underlying layer. For information about editing the mask, see Editing masks.
For information about stacking layers, see Changing the order of layers in an image.
Edit workspace
Choose Layers New Mask Layer From Image to open the Add Mask From Image dialog box. |
4
Open the Source Window drop-list, and choose the image. |
5
In the Create Mask From group box, choose one of the following options: |
Source luminance — determines the degree of masking based on the luminance value of the pixel color. Lighter colors produce less masking; darker colors produce more masking. Transparent areas completely mask the layer. |
Any non-zero value — applies masking without gradation. Pixels with an opacity between 1 and 255 pixels become white; transparent pixels become black. Transparent areas completely mask the layer. |
Source opacity — determines the degree of masking based on the opacity of the image. Fully opaque pixels produce no masking; partially transparent pixels create more masking; transparent pixels produce full masking. |
The mask layer and the selected layer are added to a new layer group. The mask layer applies to the selected layer only.
For information about editing a mask, see Editing masks.
To display the mask on the image, click the Highlight mask area button
on the Layers palette.
To apply the mask layer to all underlying layers, drag it from the layer group to the main level on the Layers palette.
Edit workspace
If you apply a mask layer to the background, the background is automatically converted to a raster layer.
For information about editing masks, see Editing masks.
Edit workspace
Choose Image Split Channel, and choose one of the following: |
4
In the Source Window drop-list, choose the channel that you want to use for the mask. |
5
In the Create Mask From group box, choose the Source luminance option. |
For information about color channels, see Working with colors and materials.
