When you display the Customize dialog box, the entire Corel PaintShop Pro workspace transforms into customize mode. You can choose which menus are displayed and how a menu opens when you select it. You can also reset the menus to the default settings.
Edit workspace
In the Select context menu drop-list, select the menu that you want to modify. |
4
From the Menu animations drop-list, choose one of the following animation styles for menu opening: |
None — applies no animation effect |
Unfold — opens the menu starting from its top-right corner to its bottom-left corner |
Slide — opens the menu from top to bottom |
Fade — gradually opens the entire menu, from a faded look to fully visible |
Edit workspace
