You can draw polygons and stars.
| To draw a symmetric shape |
| 1 | On the Tools toolbar, select the Symmetric Shape tool |
| Note: If you want to place the symmetric shape on the current vector layer, mark the Create on Vector check box on the Tool Options palette. If no vector layer exists, marking this check box creates one for the symmetric shape. If this check box is unmarked, the symmetric shape is placed on a raster layer. Placing a symmetric shape on a vector layer makes it easier to edit. |
| 2 | On the Materials palette, click the Background and Fill properties box, and choose a fill color. |
| 3 | Click the Foreground and Stroke properties box, and choose an outline color. |
| 4 | On the Tool Options palette, click one of the following buttons: |
| • | Draw Polygon |
| • | Draw Stellated |
| If you want to display the shape’s nodes, mark the Show Nodes check box. |
| 5 | Type or set a value in the Number of sides control. |
| 6 | Drag to draw the shape. |
| 7 | Click the Apply button |
Mark the Rounded Outer check box.
Mark the Rounded Inner check box.
Type or set a value in the Radius control.
You can save Tool Options palette settings as presets. For more information, see Using and creating presets.
You can also choose line style options such as style, stroke width, and join and miter limit settings. For more information, see Drawing lines.
