You can snap images to the nearest gridline on the layout.
| To resize an image in print layout |
| 1 | Click the Resize button |
| 2 | Choose one of the following options: |
| • | Percent of original — resizes an image by a percentage you specify in the Width or Height boxes |
| • | Actual / Print size — resizes an image by the dimensions you specify in the Width or Height boxes without changing its aspect ratio |
You can also resize an image manually by dragging a corner handle.
| To use borders in a print layout |
| 1 | Choose View |
| 2 | Mark the Use Borders check box, and type or set values in the Horizontal border size and Vertical border size controls. |
| The default border width is 0.5 inches (1.27 centimeters). |
| 3 | Click OK. |
If you want to resize images to fit in their cells, mark the Stretch to fit check box.
As you decide where to move images, you can place them temporarily in the workspace around the page.
You can also arrange images manually by dragging the image to a new position on the page.
| To display the grid |
| • | Choose View |
| To snap images to the layout grid |
| • | Choose View |
| To change layout grid settings |
| 1 | Choose View |
| The Print Layout Options dialog box appears. |
| 2 | In the Grid Settings group box, mark any of the following check boxes: |
| • | Show Grid — displays the grid |
| • | Snap-to-Grid — snaps images to the gridlines when you position them |
| Note: If you mark the Show Grid check box, you can mark the Dot Grid check box to use a dotted-line grid instead of a solid-line grid. |
Click the Grid color area, and choose a color from the color palette.
Set values in the Horizontal Spacing and Vertical Spacing boxes.
| To save a custom layout as a template |
| 1 | Click the Save Template button |
| The Save dialog box appears. |
| 2 | Enter a name for the new template in the Name field. |
| If you want to save the image links with the template, mark the Save with Images check box. |
| 3 | Click OK. |
| To rotate an image in a layout |
| 1 | Select the image. |
| 2 | Choose Image, and then choose one of the following commands: |
| • | Rotate Right |
| • | Rotate Left |
| To position an image in a layout |
| • | Drag the image to a new position on the page. |
