If you no longer need a print template that was saved, you can easily delete it.
| To edit template cells |
| 1 | Click the cell you want to edit. |
| If you want to edit multiple cells, hold down Ctrl while clicking the cells. |
| 2 | Choose Edit, and then choose the commands you want to apply to the template cells. |
| To enter descriptive text for a template |
| 1 | Load a template, or create a new template. |
| 2 | On the Print Layout toolbar, click the Save Template button |
| The Save dialog box appears. |
| If you want to create a specific name for the template, enter it in the Name field. |
| 3 | In the Description field, enter the information you want. |
| If you want to save the template with the images it contains, mark the Save with images check box. |
| 4 | Click OK. |
| If you did not change the template name, you are prompted to overwrite the template or cancel the action. |
| To move the template position |
Hold down Ctrl, and press the arrow keys.
Hold down Ctrl and Shift, and press the arrow keys.
| To revert a template with images to a layout |
| 1 | Open the template you want to edit. |
| 2 | Click the New Template button |
| A dialog box appears, asking whether to keep the current images in the new template. |
| 3 | Click Yes. |
| To save a template with images |
| 1 | Click the Save Template button |
| 2 | Enter a name for the new template in the Name field. |
| 3 | Mark the Save with Images check box. |
| 4 | Click OK. |
| To delete a template |
| 1 | Choose File |
| 2 | In the Print Layout window, click Open Template |
| The Templates dialog box appears. |
| 3 | Choose a category from the Select A Category list. |
| 4 | Select the thumbnail of the template you want to delete. |
| 5 | Click Delete. |
