You can also import gradients in the GRD file format.
| To export a gradient |
| 1 | In the Gradient Editor, select the gradient you want to export, and adjust its settings. |
| 2 | Click Export. |
| The Export dialog box appears. |
| 3 | Select the folder in which you want to save the gradient. |
| The default gradients are stored in the Gradients folder within the Corel PaintShop Pro program folder. |
| 4 | In the File name field, type a name for the new gradient. |
| 5 | Click Export. |
| To import a GRD gradient |
| 1 | In the Gradient Editor, click Import. |
| The Import dialog box appears. |
| 2 | Select the folder that contains the gradient you want to import. |
| All GRD files are listed in the folder. |
| 3 | Select the gradient’s filename, and click Import. |
