Feathering softens the area between a selection and the rest of the image by gradually increasing the transparency of the pixels along the edge of the selection. You can specify the width of the feathered area.
When you copy or move a selection, feathering helps blend the selection into the surrounding area so that the image appears more natural. The higher the feathering value is, the softer the edges are. A feathering value of 0 creates a selection with distinct edges.
An unfeathered selection (left) and a feathered selection (right)
You can apply feathering as you make a selection, or you can apply it after the selection is created. The level of feathering and its position around the selection marquee can be adjusted after the selection is created. For more information about creating selections, see Creating selections.
Edit workspace
Choose Selections Modify Feather. |
Edit workspace
Choose Selections Modify Inside/Outside Feather. |
You can click the Toggle Selection button
in the Inside/Outside Feather dialog box to toggle between a preview of only the selection and a preview of the selection and the rest of the image.
Edit workspace
Choose Selections Modify Unfeather. |
Type a value in the Threshold control to specify the amount of feathering you want to remove. |
