Sometimes, the easiest way to make a complicated selection is to select the part of the image that you don’t want and then invert the selection. For example, in a picture of a person against a solid-color background, you can select the background and then invert the selection, so that the person is selected instead of the background.
By selecting a solid background (left) and inverting the selection, you can isolate a complex, multicolored foreground (right).
You can also clear a selection, which removes the selection marquee and integrates the selection back into the image. After clearing the selection, you can resume your editing of the entire image.
Edit workspace
Edit workspace
Choose Selections Select None. |
If you deselect a floating selection, the selection is defloated and placed in the underlying layer if the layer is a raster layer. If the underlying layer is a vector layer or an Art Media layer, a new raster layer is created, and the selection is defloated to it.
You can also clear a selection by right-clicking in the image outside the selection marquee or by pressing Ctrl + D.
