When you save a mask to an alpha channel within an image that is saved in PspImage format, you can load that mask from the alpha channel into the same image or into any other image.
The Masks folder of the Corel PaintShop Pro program folder contains sample masks that you can load into images, such as gradients and several types of circles and squares that frame images. Mask files have a .PspMask filename extension.
Edit workspace
Choose Layers Load/Save Mask Load Mask From Alpha Channel to open the Load Mask from Alpha Channel dialog box. |
In the Load from Document drop-list, choose the image that contains the alpha channel that you want to load. Choose only open images with existing alpha channels. |
5
In the Orientation group box, choose one of the following options: |
6
In the Options group box, choose one of the following options: |
Hide all mask — hides pixels surrounding a loaded mask that is smaller than the current image canvas |
Show all mask — shows pixels surrounding a loaded mask that is smaller than the current image canvas |
The mask layer applies to the selected layer only. To apply the mask layer to all underlying layers, drag it from the layer group to the main level.
Edit workspace
Choose Layers Load/Save Masks Load Mask From Disk to open the Load Mask From Disk dialog box. |
In the Mask group box, click the drop-list to choose from mask and image files. |
4
Fit to canvas — adjusts the mask to fit the current image canvas (stretching or contracting as needed) |
Fit to layer — adjusts the mask to fit the current layer data (stretching or contracting as needed). If the layer has not been shifted beyond the edges of the canvas, this option produces the same results as the Fit to Canvas option. |
As is — positions the mask in the upper-left corner of the current layer. This option does not change the mask proportions. If the mask image is smaller than the current layer, Corel PaintShop Pro masks all pixels outside of the mask image boundaries. |
5
In the Options group box, choose an option to specify whether any pixels Corel PaintShop Pro surrounding the loaded mask data are shown or hidden. These options affect the mask only if the Orientation option is As Is and the loaded mask is smaller than the current image canvas. |
Hide all mask — makes surrounding pixels black to hide underlying pixels |
Show all mask — makes surrounding pixels white to show underlying pixels |
Use image value — makes surrounding pixels white or black, depending on whether the Show All Mask option or the Hide All Mask option was applied to the original mask. |
Corel PaintShop Pro adds the mask layer and the selected layer to a new layer group. The mask layer applies to the selected layer only. To apply the mask layer to all underlying layers, drag it from the layer group to the main level.
