Merging layers in an image is also referred to as "flattening" an image. You can choose to merge all layers or only selected layers in an image. Merging layers decreases the memory requirements for the image. Layers are merged according to blend modes, vector data and vector text are converted to raster data, and transparent areas of the background layer are replaced with white.
Many file formats, such as JPEG, GIF, and TIF, do not support multilayer images. When you save images to these formats, Corel PaintShop Pro merges all layers into a single background layer. When you save to the PSD (Photoshop) format, the image maintains raster and adjustment layers, but vector layers and art media layers are converted to raster layers.
The following table describes how layer types are merged.
Important! You should always make a backup copy of the original PspImage image before you merge layers. After you merge layers, you cannot edit the layers separately.
Edit workspace
Choose Layers Merge Merge Down. |
To merge all layers, choose Layers
Merge
Merge All (Flatten).
Edit workspace
Choose Layers Merge Merge Visible to merge all visible layers into one raster layer. |
Invisible layers are not affected. The merged layer, which maintains the transparency information of the original layers, appears at the position of the active layer.
If the selected layer is in a group, only the visible layers in that group are merged. If the layer group is marked as invisible (making all layers within the group invisible), then none of the layers within the group are merged.
Edit workspace
Choose Layers Merge Merge Group to merge all layers in the group into one raster layer. |
