You can edit the properties of lines and curves. You can reshape a curve by changing its nodes the shape of the contour at a node by changing the node type, by modifying its line segments on either side of a node, or by connecting line segments. You can also cut a line segment. When you cut a closed path or contour, you open it. When you cut an open path or contour, you create two separate contours.
Edit workspace
You can also edit the curve by clicking the Pick tool
, selecting the curve, and modifying any of the settings on the Tool Options palette.
Edit workspace
Line After — straightens the segment after the node |
Edit workspace
You can save a set of Tool Options palette settings as presets. For more information, see Using and creating presets.
Edit workspace
When you click the Knife Mode button, you can cut through all selected contours in an object.
