You can modify the edges of a selection by smoothing its boundary or by adding a border.
Edit workspace
Choose Selections Modify Smooth. |
Preserve Corners — preserves the shape of the corners. Unmark this check box if you want to smooth the corners. |
Smoothing amount — specifies the amount of smoothing to apply around the selection |
Corner scale — specifies the amount of smoothing to apply around the corners of the selection. This control is not available when the Preserve Corners check box is not marked. |
You can click the Toggle Selection button
in the Smooth Selection dialog box to toggle between a preview of the selection and a preview of the selection and the rest of the image.
Edit workspace
Choose Selections Modify Select Selection Borders. |
