Important! This command works on 16 million–color and grayscale images only. For more information about increasing the color depth of an image, see Working with colors and materials.
| To move the selection marquee |
| • | Using the Selection tool, right-click and drag the selection marquee to a new position. |
You can also move the selection marquee by right-clicking and dragging with the Move tool
| To move a selected image area |
| • | Perform a task from the following table. |
In the Tool Options palette set Mode to Replace, and then drag the selection with one of the selection tools (Selection, Freehand, or Magic Wand tool).
Hold down Ctrl, and press an arrow key.
Hold down Shift, and press an arrow key.
Hold down Shift and Ctrl, and press an arrow key.
| To copy and move a selected image area |
| • | With the Selection tool active, set the Mode control to Replace, hold down Alt, and drag the selection. |
Hold down Alt, and press an arrow key.
Hold down Alt and Ctrl, and press an arrow key.
Hold down Alt and Shift, and press an arrow key.
Hold down Alt, Shift, and Ctrl, and press an arrow key.
| To float a selection |
| • | Choose Selections |
| To defloat a selection |
| To promote a selection to a layer |
| 1 | Create a selection in the image. |
| 2 | Choose Selections |
| The new Promoted Selection appears above the original layer. |
To place a selection as a layer within another image, copy the selection, open the other image, and choose Edit
Paste As New Layer.
| To clip a selection to the canvas |
| 1 | Move part of the selection off the image canvas. |
| If necessary, expand the image window to reveal the gray area that appears outside the image borders. |
| The selection is defloated, which makes more edit options available. |
| 3 | Choose Selections |
| The selection area outside the image borders is removed. |
| To rotate a selection |
| 1 | Choose Image |
| The Free Rotate dialog box appears. |
| 2 | In the Direction group box, choose either Right or Left to specify the rotation direction. |
| 3 | In the Degrees group box, set the number of degrees to rotate. |
| If you want to type a value between 0.01 and 359.99, mark the Free option. |
| 4 | Unmark the All layers check box. |
| 5 | Click OK. |
You can also rotate a selection interactively by using the Pick tool
. Before the rotation is applied, the selection is promoted to a layer.
