You can open most image formats in Corel PaintShop Pro. You can open the images by using the menu bar or by using the Manage workspace. You can associate specific file formats with Corel PaintShop Pro, such as JPEG, TIF, or PNG, so that these files will open in Corel PaintShop Pro when you double-click them. For more information about setting file format associations, see Setting file format associations.For a list of the file formats that you can open in Corel PaintShop Pro, see Files supported by Corel PaintShop Pro. For information on RAW files, see Supported RAW file formats.
| To open an image |
| 1 | Choose File |
| 2 | In the Look in drop-list, choose the folder where the file is stored. |
| 3 | Click the name of the file that you want to open. |
| If you want to open multiple files, hold down Ctrl, and click the filenames. |
| 4 | Click Open. |
In the Open dialog box, mark the Show preview check box.
In the Open dialog box, mark the Enable Pre‑processing check box, and choose a script from the drop-list.
| To open a recently viewed file |
| • | Choose File |
By default, the Recent Files menu lists four recently viewed files. You can choose to list up to 10 files. For more information, see To set the number of files that appear in the Recent Files list.
| To open an image from the Manage workspace |
| • | Click a thumbnail to select the file. |
| To view thumbnails from another folder, click Browse More Folders on the Navigation palette, and from the Browse For Folder dialog box that appears, choose the folder you want. The folder appears in the Folders list. |
| You can work with the file in the Manage workspace, or click the Adjust tab or Edit tab to edit the file in another workspace. |
| To open a RAW photo image |
| • | Do one of the following: |
| • | Choose File |
| • | Double-click on a RAW image thumbnail. |
| • | Hold down Ctrl, and click the filenames or thumbnails to open multiple files. |
| The Camera RAW Lab dialog box opens. This dialog box lets you adjust the settings that are stored with the RAW photo file. |
| To close an image |
| • | Choose File |
In the Edit workspace, you can also close an image by clicking the Close button
above the image.
