You can rename multiple files at the same time.
Edit workspace
Choose File Batch Rename to open the Batch Rename dialog box. |
6
Click Modify to open the Modify Filename Format dialog box. |
Date — to add the current date to the file name |
Document Name — to add the original file name to the new file name, and to change the case |
Sequence — to add the numerical position of a file in the renaming process |
Time — to add the current time to the file name |
8
Click Add for each option you want to move into the Included list. |
You can use click the Move Up
and Move Down
buttons in the Modify Filename Format dialog box to rearrange the order of options you choose from the Rename Options list.
