You can automate actions that must be performed in order to further edit an image.
For example, some commands can be performed only on images with a bit depth of at least 8 bits per pixel. When you choose a command for an image with a bit depth lower than 8 bits per pixel, the Auto Actions dialog box appears with the message that the image must be converted to a higher bit depth in order to proceed with the command.
Edit workspace
Manage workspace
Choose File Preferences General Program Preferences. |
Never — prevents the action from happening |
Note: Choosing Never makes certain menu commands inactive if the action is required to complete the command. Some items in the list do not have this option available. |
Always — performs the action silently without prompting you |
Prompt — asks if you want to perform the action |
You can set all actions in the list to a certain option by clicking Always All, Prompt All, or Never All.
You can reset all the actions in the list to the default settings by clicking Reset.
