| To set Undo and Redo preferences |
| 1 | Choose File |
| 2 | From the left pane, choose Undo. |
| 3 | To enable Corel PaintShop Pro to undo actions, mark the Enable the undo system check box. |
| This enables you to set all the items in this area of the Undo page. |
| 4 | Perform one or more of the following tasks and click OK. |
Mark the Limit undo/redo disk usage to check box, and type or set a value in the control.
Mark the Limit undo/redo to check box, and type or set a value in the control.
Mark the Enable fast redo check box. This may slightly slow down the undo process, so if you rarely perform a redo, but use undo frequently, you may want to unmark this check box.
Type or set a value in the Non-undoable steps in History Palette control.
