Corel PaintShop Pro lets you automatically save your work as you move between tasks. For example, if you make some edits in the Adjust workspace, and switch to another photo or workspace, your changes will be applied automatically.
It is recommended that you enable Auto-Preserve if you enable Autosave. For more information, see Setting Auto-Preserve preferences.
Edit workspace
Manage workspace
Choose File Preferences Autosave Settings. |
The Autosave Settings dialog box appears. |
To enable Autosave, do any of the following: |
Click the Adjust workspace tab and mark the Save edits to the current image automatically when the next image is selected check box. |
Click the Edit workspace tab and mark the Automatically save backup copies of all open files every __ minutes check box. Type or set a value in the minutes control. |
To find out where Corel PaintShop Pro saves the autosaved files, choose File
Preferences
File Locations and select the Undo/Temporary Files folder from the File Type list.
