With Corel PaintShop Pro, you can use plug-ins that provide compatibility with Adobe Photoshop files. The most common plug-in filename extension is .8B*. You can choose to limit the use of plug-ins to those having the .8B* filename extension, or you can choose to use plug-ins having any filename extension.
Edit workspace
Manage workspace
Choose File Preferences File Locations. |
Unmark the Limit Loaded plug-in files to those with an .8B* extension check box.
Mark the Allow file format plug-ins to request pre-filtering of support file types check box.
Edit workspace
Manage workspace
You can also add any subfolders stored in the plug-in folder you add by marking the Use sub folders check box.
