The Straighten tool lets you position a straightening bar within an image.
| To straighten an image |
| 1 | On the Tools toolbar, choose the Straighten tool |
| A straightening bar with end handles appears on the image. |
| 2 | Drag each handle of the straightening bar to align it with the part of the image that you want to straighten. |
| 3 | On the Tool Options palette, choose one of the following options from the Mode drop-list: |
| • | Auto — automatically straightens the image based on the position of the straightening bar |
| • | Make vertical — rotates the image to make the straightening bar vertical |
| • | Make horizontal — rotates the image to make the straightening bar horizontal |
| 4 | Click the Apply button |
Before clicking the Straighten tool, click the layer name on the Layers palette.
Mark the Rotate all layers check box on the Tools Options palette.
Type or set a value in the Angle control on the Tools Options palette.
Mark the Crop image check box on the Tools Options palette.
Unmark the Crop image check box on the Tools Options palette.
You can also double-click the image to apply the command.
