When you choose a brush, you can modify its settings to achieve the effect you want. You can also reset the brush to its default settings.
When applying paint, you can undo and redo multiple brushstrokes.
Edit workspace
With the Airbrush tool, you can build up color in one area by clicking and holding the mouse at one position.
To paint a straight line, click once at the beginning point, press Shift, and then click the end point. To continue the straight line, move to the next point, press Shift, and then click again.
Edit workspace
Edit workspace
Click the Undo button on the Standard toolbar. |
You can also press Ctrl + Z or use the History palette to undo the stroke.
Edit workspace
Click the Undo button on the Standard toolbar multiple times. |
You can also press Ctrl + Z multiple times or use the History palette to undo multiple strokes.
You can redo strokes by clicking the Redo button
on the Standard toolbar, by pressing Ctrl + Alt + Z, or by using the History palette.
