The Marker tool
lets you apply pigment that resembles drawing with a marker on a canvas. Marker pens are a slightly wet medium, though generally not wet enough to interact with other wet media. The pigment goes on the canvas with a multiply function, simulating the interaction of using a pen repeatedly on the same spot. Pens generally have a very sharp fall-off at the stroke edge, and there is full canvas penetration even at light pressure.
Edit workspace
Marker tool options include
Shape — defines the shape of the marker tip |
Size — defines the size of the tool head in pixels |
Thickness — defines the aspect ratio of the tool head |
Rotation — defines the angle of head rotation in degrees |
Head Tracking — controls whether the tool head bends around the path of the stroke, or whether it remains at a fixed angle |
Trace check box — allows the Marker tool to select the pigment color by sampling the data below the center of the tool, regardless of the layer type |
Important! When you hold down the mouse button to begin the stroke, note that a single sample is performed and the resulting color is used for the duration of the stroke.
