Corel PaintShop Pro lets you optimize PNG files to maximize quality and minimize file size.
To optimize and save a PNG file |
1 | Choose File ![]() ![]() |
The PNG Optimizer dialog box appears. The preview areas show the current image on the left and the resulting PNG file on the right. |
2 | Click the Colors tab, and choose one of the following image type options: |
• | Palette-Based — for images with 256 colors or less |
• | Grayscale (8-bit) |
• | 16.7 million color (24-bit) |
If you choose the Palette-Based method, you can choose the number of colors in the image and the amount of dithering applied. |
3 | Click the Transparency tab, and choose one of the following transparency types: |
• | No transparency — saves the image without transparency |
• | Single color transparency — lets you make one color transparent by clicking a color swatch or clicking a color in the image, and entering a value in the Tolerance control. |
4 | Click the Gamma tab, and set or type a value in the Gamma control if you want to change the default value. |
5 | Click the Format tab, choose one of the following options: |
• | Non-interlaced — the image downloads one line at a time, starting from the top |
• | Interlaced — the image is displayed incrementally in several passes; detail is added with each pass. Use this option with larger images so that the viewer can get an idea of how the image looks while waiting for it to download |
6 | Click OK to open the Save As dialog box, navigate to the folder in which you want to save the new image, type a name for the file, and click Save. |
You can click the Download Times tab to preview the file size of the compressed file and an estimate of the download time at four modem speeds.
To use the PNG wizard |
The PNG Optimizer dialog box appears. |
2 | Click Use wizard and follow the instructions. |
3 | Click Finish to close the wizard and open the Save As dialog box, where you type a name and select a location for saving the GIF file. |
On page 6 of the wizard, click Back to return to the previous pages. Then, change the settings you want, and return to page 6 to view the results.
