| To create a swatch |
| 1 | On the Materials palette, click the Swatches tab |
| 2 | Click the Create New Swatch button |
| 3 | Type a name for the swatch. |
| This name appears as a tooltip when you hold the pointer over the swatch on the Materials palette. |
| 4 | Press Enter. |
| The Material Properties dialog box appears. |
| 5 | Select the style (color, gradient, or pattern) and the texture for the material. |
| 6 | Click OK. |
You can also click the More Options button
on the Swatches tab of the Materials palette, and then choose New Swatch.
| To select a swatch |
| 2 | Do one of the following: |
| • | To select a swatch as the foreground material, click the swatch. |
| • | To select a swatch as the background material, right-click the swatch. |
| To edit a swatch |
| 2 | Double-click the swatch you want to edit. |
| 3 | Edit the style (color, gradient, or pattern) or the texture for the material. |
| 4 | Click OK. |
You can also click the swatch, click the More Options button
, and then choose Edit Swatch.
| To delete a swatch |
| 2 | Click the swatch you want to delete. |
| 3 | Click the Delete Swatch button |
, and choose Delete Swatch.
| To rename a swatch |
| 2 | Click the swatch you want to rename. |
| 3 | Click the More Options button |
| To change how swatches are displayed |
| • | On the Materials palette, click the Swatches tab |
Click the All button
