Adding and closing contours
You can add new contours to any existing object. The new contour will have the same properties, including color, material, line style, and so on, as the selected object. You can also duplicate contours.
To add a contour to an object Back to Top
Edit workspace
To close a contour Back to Top
Edit workspace
When you close a contour, Corel PaintShop Pro draws a segment from the contour’s start node to its end node.
