Applying Photo effects
You can apply different Photo effects to your images to simulate some traditional photo techniques and processes.
Time Machine
The Time Machine lets you recreate some popular photographic styles from the past. It lets you choose from seven styles, which range from the year 1839 to the 1980s. For information about the Time Machine, see Creating vintage-style photos with the Time Machine.
Film and Filters
Corel PaintShop Pro lets you experiment with effects that are inspired by different types of camera film and filters. For information about applying film and filter effects, see Applying film and filter effects to photos.
Black and White Film
You can simulate taking a photo with black-and-white film. To modify the effect, you can apply a wide range of RGB values as well as adjust image brightness and clarity.
Filter color adjustments in the Black and White Film dialog box can create very different results from the original photo (left-most image in top tow).
Infrared Film
You can simulate the look created when you take a photo with black-and-white infrared film and an infrared pass lens filter on the camera. To enhance the effect, you can adjust settings for film grain and flare.
Original photo (left) and the same photo with the Infrared Film effect applied (right)
Sepia Toning
You can simulate the look created when you take a photo with sepia film. Sepia-toned images are similar to black-and-white photos (also known as grayscale photos), except the tones are brown instead of gray.
Selective Focus
You can create a quick miniature effect (also known as a tilt-shift effect) so that the scene in a photo resembles a miniature model or toy. The illusion is created by adjusting the depth of field, usually across a specified horizon line, and increasing the saturation of the photo.
An urban scene (left) appears to be transformed into a miniature model (right).
You can also use Selective Focus to apply a quick depth of field effect to any photo. For general information about depth of field, see Controlling depth of field.
Photo tip: Photos taken from high vantage points usually make the best candidates for a miniature effect.
Vignette
You can fade the edges of a photo to create a vignette effect. You can control the appearance of the edges by choosing a shape and color (light or dark), and adjusting the amount of blur, glow, and feathering.
Retro Lab
Inspired by photos taken spontaneously with a vintage-style pocket camera, such as LOMO, Diana, or Holga, the Retro Lab lets you apply a fun retro effect. For more information, see Using Retro Lab.
Graduated Filter
You can apply a color gradient to your photos to simulate the effect achieved by using a graduated filter on your camera lens. For more information, see Applying a gradient with the Graduated Filter effect.
To apply the Black and White Film effect Back to Top
Edit workspace
In the Filter Color group box, click or drag inside the color spectrum to set the RGB filter color.
The Red, Green, and Blue values and the After pane are updated.
In the Filter Color group box, place the filter toward the middle of the color spectrum, or click the Reset to Default button below the After pane.
In the Filter Color group box, click Suggest Color.
In the Adjustments group box, drag the Brightness slider, or type or set a value in the control.
In the Adjustments group box, drag the Clarify slider, or type or set a value in the control.
To apply the Infrared Film effect Back to Top
Edit workspace
To apply the Sepia Toning effect Back to Top
Edit workspace
To apply a miniature effect by using Selective Focus Back to Top
Edit workspace
Interactive elements in the Before pane: (1) Center line (for Planar Selection Tool), (2) Rotation handle, (3) Sizing handle, (4) Feathering handle
You can use the Selective Focus effect to apply a quick depth of field effect. Adjust the settings to achieve a natural look.
To apply a Vignette effect Back to Top
Edit workspace
