Creating layouts
You can create a print layout and position images individually, or you can apply the same settings to all of the images.
By rotating and zooming, you can change the print layout of your images. Images are displayed at 100% magnification by default. You can zoom in to get a closer look at image detail, or zoom out to view a larger portion of the image.
When you use a print layout, you can add descriptive text captions, undo or redo the changes you make, and save the layout for future use as a template.
To add images to a layout Back to Top
Edit workspace
Click the Print button .
Choose File Print Setup. In the Print Setup dialog box, make changes to any of the settings.
Click the Close Print Layout button .
To position images in a layout Back to Top
Edit workspace
You can display the grid if you want to position images with precision.
To rotate an image in a layout Back to Top
Edit workspace
To zoom Back to Top
Edit workspace
Click the Zoom In 10% button .
Click the Zoom Out 10% button .
Click the Zoom Rectangle button . Drag in the page layout to choose an area to zoom in on.
Click the Zoom to Page button .
To create a caption Back to Top
Edit workspace
Right-click the text box, and choose Rotate Right or Rotate Left.
To undo or redo a change to a layout Back to Top
Edit workspace
To change the Print Layout workspace Back to Top
Edit workspace
Click the Grid color area, and choose a color from the color palette.
Set values in the Horizontal Spacing and Vertical Spacing controls.
