Cutting out image areas
You can use the Object Extractor to cut out an image area from the surrounding background. You can then edit the cutout separately from the background, display it against a different background, or combine it with other images.
Object Extractor workflow: (1) Outline the edges of the image area; (2) add a fill; (3) preview the cutout, and touch it up if necessary; (4) bring the cutout into the image window; (5) place the cutout against a different background image (optional).
To cut out an image area Back to Top
Edit workspace
Choose the Eraser tool , and drag over the selection marquee that you want to delete.
Move the Accuracy slider to a higher value if the object has an intricate or complex outline.
The Accuracy slider is available only after you click Process.
Click Reset. The Reset button is available only before you click Process and clears both the fill and the selection outline.
Mark the Hide Mask check box.
Click the Zoom to 100% button .
Click the Fit Image to Window button .
Using the Pan tool , drag the image until the area you want to see is visible.
The background layer is automatically promoted to a raster layer when you use the Object Extractor command.
You can switch from the Brush tool to the Eraser tool by right-clicking and dragging in the preview area.
