The following table describes important conventions used in the Help.
Menu
Choose File
Choose an option from the Selection Type drop-list on the Tool Options palette.
mark and unmark
To preserve the current print size, mark the Maintain original print size check box.
The Enter key on your keyboard
To save this gradient as a swatch that you can access later, click the Add to swatches button, type a name, and press Enter.
Although you can apply the Texture Preserving Smooth command to the entire image, the command works best when you select the problem area.
