You can duplicate a layer within an image. You can use the duplicated layer as a starting point for a new layer, or you can try out edits and effects on the duplicated layer while keeping the original layer intact. You can also copy a layer to another image by copying and pasting or by dragging the layer into another image.
Edit workspace
You can also right-click the layer name and choose Duplicate.
You can also choose Edit
Copy to copy the layer and then choose Edit
Paste As New Layer.
Edit workspace
4
Choose Edit Paste As New Layer. |
In the Edit workspace, open both images. |
In the Layers palette, drag the layer that you want to copy from one image to the tab of the other image, and when the other image becomes active, drop the layer in the position you want in the Layers palette. |
The Edit workspace must be in Tabbed Documents mode (Window > Tabbed Documents) to drag and drop layers between images.
