Editing and saving layouts
Corel PaintShop Pro includes many templates with different layouts that you can use to print your images. The layouts you create can be saved as templates.
You can arrange images in a layout automatically or manually. Before you arrange images automatically, you must choose whether to include borders. If you do not use borders, Corel PaintShop Pro may arrange the images with touching edges. You must also choose whether to size the images to fit the layout. If you do not choose this option, Corel PaintShop Pro keeps them the same size or, if necessary, makes them smaller to fit the layout. Corel PaintShop Pro divides the page into sections of equal size and places each image in a section. Only images on the page or in the workspace are used.
Horizontal and vertical gridlines help you position items evenly on a page. You can display or hide grids and set preferences for grid spacing and appearance. When you display grids, they appear in any image window that is open.
You can snap images to the nearest gridline on the layout.
To resize an image in print layout Back to Top
Edit workspace
Resizing an image for printing can result in poor image quality. When you enlarge an image, it loses detail and sharpness. As a general rule, it is best to avoid enlarging or reducing an image by more than 25 percent.
You can also resize an image manually by dragging a corner handle.
To use borders in a print layout Back to Top
Edit workspace
If you want to resize images to fit in their cells, mark the Stretch to fit check box.
As you decide where to move images, you can place them temporarily in the workspace around the page.
You can also arrange images manually by dragging the image to a new position on the page.
To display the grid Back to Top
Edit workspace
To snap images to the layout grid Back to Top
Edit workspace
To change layout grid settings Back to Top
Edit workspace
Click the Grid color area, and choose a color from the color palette.
Set values in the Horizontal Spacing and Vertical Spacing boxes.
To save a custom layout as a template Back to Top
Edit workspace
To rotate an image in a layout Back to Top
Edit workspace
To position an image in a layout Back to Top
Edit workspace
