• | Markers ![]() |
• | Midpoints ![]() |
Important! When you edit and save a default gradient, you permanently change the gradient. To maintain default gradients, save changes to a new gradient file. For more information about saving a gradient, see To save an edited gradient. For more information about restoring default settings, see Installing and uninstalling Corel programs.
To change the location of a marker or a midpoint |
• | Drag the marker or midpoint to a new location on the Gradient Editor. |
You can also click the marker or midpoint to select it, and then enter a value in the Location field.
To add a marker |
• | On the Gradient Editor, click a position under the gradient bar to add a color marker or click above the gradient bar to add a transparency marker. |
To delete a marker |
• | On the Gradient Editor, drag a marker away from the gradient bar. |
To change the color for a marker |
1 | On the Gradient Editor, click a marker below the gradient bar to select it. |
The triangle at the top of the marker turns black. |
2 | Perform one of the following tasks, and click OK. |
Click the Fore button
Click the Back button
Click the User button
Click the swatch beside the User button and select from the Color page, or right-click to select from recently used colors.
To change the transparency of a marker |
1 | On the Gradient Editor, click the marker above the gradient bar to select it. |
2 | Type or set a value in the Opacity control. |
Values range from 0% (completely transparent) to 100% (opaque). At 100%, the underlying pixels are covered completely. |
