Editing templates
In Print Layout mode, you can make changes to multiple cells at the same time. However, the position and size of a cell are locked when the layout is saved as a template, so template cells cannot be moved or resized. You can add descriptive text to a template, which can be helpful for future browsing.
If a print layout contains images that you want to print repeatedly, you can save the layout as a template with links to the images. Whenever you open the template, it displays the images in the layout.
If you no longer need a print template that was saved, you can easily delete it.
Important! When you print a template on thick paper, such as glossy photo paper, the images in the printed template may not fit perfectly inside the cell borders. You can correct this by adjusting the position of the template layout in Corel PaintShop Pro.
To edit template cells Back to Top
Edit workspace
To enter descriptive text for a template Back to Top
Edit workspace
To move the template position Back to Top
Edit workspace
Hold down Ctrl, and press the arrow keys.
Hold down Ctrl and Shift, and press the arrow keys.
If your printer consistently misprints the same way, adjust the template position, and save it with a name that specifies its use with that printer.
To revert a template with images to a layout Back to Top
Edit workspace
To save a template with images Back to Top
Edit workspace
To delete a template Back to Top
Edit workspace
