You can also import gradients in the GRD file format.
To export a gradient |
1 | On the Gradient page, select the gradient that you want to export. |
2 | Click the More Options button , and choose Export. |
The Export dialog box appears. |
3 | Select the folder in which you want to save the gradient. |
The default gradients are stored in the Gradients folder within the Corel PaintShop Pro program folder. |
4 | In the File name field, type a name for the new gradient. |
5 | Click Save. |
To import a GRD gradient |
1 | On the Gradient page, click the More Options button , and choose Import. |
The Import dialog box appears. |
2 | Select the folder that contains the gradient you want to import. |
All GRD files are listed in the folder. |
3 | Select the gradient’s filename, and click Open. |
