Moving, clipping, and rotating selections
You can move, clip, or rotate a selection. If you want to change the selection area, you can also move the selection marquee.
When you move a selection, you can leave the space empty or you can move a copy of the selection and leave the original unchanged. When you move a selection, it becomes a floating selection. When you perform a new action, Corel PaintShop Pro automatically promotes the floating selection to a new layer.
You can also float a selection, which creates a copy of the selection that you can move or modify without changing the original image. A floating selection temporarily rests above the image or layer on the Layers palette, and an icon indicates that the layer contains a floating selection. After you edit the floating selection, you can defloat it.
You can also move a selection to a separate layer. When you do this, the original selection contents are unchanged, and a copy of the selection becomes the new layer. You can edit this new layer without changing the original image.
Important! This command works on 16 million–color and grayscale images only. For more information about increasing the color depth of an image, see Working with colors and materials.
After making a selection, you can move the selection anywhere on the image, or off the canvas. If you expand the image window to show the off-canvas gray area, you can see the selection you moved. You can also clip a selection to remove the portion that is not within the image borders.
To move the selection marquee Back to Top
Edit workspace
You can also move the selection marquee by right-clicking and dragging with the Move tool .
To move a selected image area Back to Top
Edit workspace
In the Tool Options palette set Mode to Replace, and then drag the selection with one of the selection tools (Selection, Freehand, or Magic Wand tool).
Hold down Ctrl, and press an arrow key.
Hold down Shift, and press an arrow key.
Hold down Shift and Ctrl, and press an arrow key.
To copy and move a selected image area Back to Top
Edit workspace
Hold down Alt, and press an arrow key.
Hold down Alt and Ctrl, and press an arrow key.
Hold down Alt and Shift, and press an arrow key.
Hold down Alt, Shift, and Ctrl, and press an arrow key.
To float a selection Back to Top
Edit workspace
To defloat a selection Back to Top
Edit workspace
To promote a selection to a layer Back to Top
Edit workspace
To place a selection as a layer within another image, copy the selection, open the other image, and choose Edit Paste As New Layer.
To clip a selection to the canvas Back to Top
Edit workspace
To rotate a selection Back to Top
Edit workspace
When you rotate a selection, the selection becomes a floating selection, and the original image remains unchanged.
You can also rotate a selection interactively by using the Pick tool . Before the rotation is applied, the selection is promoted to a layer.
