New! Magic Fill
Magic Fill is a content-aware feature that can make unwanted elements of your photos vanish. Use your favorite selection tools to select an area or object that you want to remove and apply Magic Fill to replace the selection with a background that matches the surrounding area—even when the surrounding area is textured or varied. For more information, see Using Magic Fill to erase image areas.
New! Shape Cutter and Text Cutter tool options
Create photo objects instantly with the Shape Cutter and Text Cutter. The cutouts are filled with the underlying photo or imagery and placed in a new image with a transparent background—perfect for collage, scrapbook, and other creative photo projects. For more information, see Filling cutout shapes with images and Creating a text cutout filled with an image.
New & Enhanced! Materials palette, custom palettes, and color harmonies
The redesigned Materials palette makes it easier to select colors, and for the first time, you can build custom color palettes for your projects. A built-in dropper tool lets you sample colors in your images or from any application or Web page displayed on your desktop. Color swatches for the most recently used colors display automatically at the bottom of the palette and color harmonies help you choose colors that look great together. For more information, see Working with colors and materials.
Enhanced! Performance
New! Smart Edge technology for brushes
The Smart Edge brush mode lets you tap into content-aware technology to apply brush strokes only to specific areas that match the brush stroke sample area—no path or selection required. Smart Edge is available from the Tool Options palette for many brush-based tools. For more information, see Choosing brush options.
New & Enhanced! Drag-and-drop layers
New & Enhanced! A better way to start creative projects
Enhanced! Redesigned Adjust and Effect dialog boxes
New! XMP support for RAW files
Corel PaintShop Pro can now read and import data saved in XMP files. XMP sidecar files are created by many RAW image-editing applications, such as Corel® AfterShot™ Pro, as a way of saving image metadata without affecting the original RAW files. After editing in PaintShop Pro, you can save the metadata to the associated XMP files. For more information, see Working with XMP files.
