Processing files in batches
You can process multiple files using the Batch Process feature. Corel PaintShop Pro can make copies of original files, convert them and then save the copies in the output folder you select.
To convert multiple files to a new format Back to Top
Edit workspace
Click Modify, choose an option from the Rename Options list, and click Add. You can rename the file with the current date, document name, position of the file in the renaming process, the current time, and custom text.
Click Cancel.
In the Script group box, mark the Use Script check box and choose a script from the drop-list.
In the Batch Progress dialog box, click Save Log, and choose the folder in which you want to save the log.
To run a script on multiple files Back to Top
Edit workspace
Click Cancel.
Mark the Stop on error check box. If you don’t mark it, the program processes all the images without stopping. The error messages appear in the Batch Conversion Status dialog box.
Mark the Run script in silent mode check box.
