Removing digital noise
The term "noise" as it relates to photos refers to small specks of color that interfere with image clarity. These specks are usually caused by poor lighting conditions or the limitations of the sensor in your digital camera. For example, when you zoom in on a photo of a clear blue sky, you may see tiny specks of orange, red, purple, green, or other colors.
Corel PaintShop Pro gives you two fast, powerful commands for removing noise from your photos: One Step Noise Removal and Digital Noise Removal. When you use a noise removal command, the program analyzes your photo, identifies the noise artifacts, and applies corrections based on these identified areas, while preserving the important edge details of your photo.
The image on the left looks grainy because of digital camera noise. The image on the right appears smoother and less grainy after the noise has been removed.
You can automatically apply noise correction to your photo with the One Step Noise Removal command. You can also control more precisely how the same corrections are applied by using the more comprehensive Digital Noise Removal command.
The Digital Noise Removal command gives you more control over the removal of digital camera noise in your photos.
Photos taken with the same camera tend to have noise in the same areas. You can create a preset to apply the same corrections to all of these photos.
This command could be an ideal solution in the following scenarios:
To remove digital noise quickly Back to Top
Edit workspace
To use advanced options for removing digital noise Back to Top
Edit workspace
Unmark the Link detail sizes check box, and type or set values in the Small, Medium, and Large controls.
You can have a maximum of 10 sampling regions.
You should avoid sampling an image edge, or pure black or pure white regions of the image, which can result in excessive smoothing.
The Digital Noise Removal command is not designed to remove moire patterns. For information about removing moire patterns, see To remove moire patterns.
To save settings as a preset specific to an image and camera, mark the Camera preset check box and click the Save Preset button . When the Camera preset check box is marked, the Load Preset drop-list displays only previously saved camera presets, not the standard presets. To save settings as a standard preset, unmark the Camera preset check box, and click the Save Preset button.
For best results when working with JPEG images, choose Adjust Add/Remove Noise JPEG Artifact Removal before using the Adjust Digital Noise Removal command.
To protect image areas from noise corrections Back to Top
Edit workspace
You can remove color adjustments for a selected color range by clicking Reset Current. To remove all color adjustments, click Reset All.
