Removing flaws and objects
You can remove flaws and objects in your images by using the Clone Brush tool or the Object Remover tool. The Clone Brush tool lets you remove flaws and objects by painting over them with another part of the image. The paint source can be a part of the same layer, another layer in the image, a merged image, or a layer from another image.
The Clone Brush tool was used to remove the cracks on the wall from the photo on the left.
The Object Remover tool lets you remove objects when the surrounding area is fairly uniform in color and texture. This tool is similar to the Clone Brush tool in that it lets you identify the area to remove and then choose a background for covering that area.
The Object Remover tool was used to remove one boat from the water.
To clone a part of an image Back to Top
Edit workspace
When you clone an image area, you must select a source area with data.
If your image contains a selection, you must right-click within the selection to set your clone source. If you are using a pen tablet, you can achieve the same result by holding down Shift.
You can also hold down Shift and click the image to set the source point.
You can resize the brush interactively by pressing Alt while dragging in the image window.
To remove objects from a photo Back to Top
Edit workspace
Feather a selection made with the Freehand Selection tool
Before making the selection, adjust the Feather control on the Tool Options palette.
Before clicking the Apply button, adjust the Opacity control on the Tool Options palette.
Mark the Use all layers check box to choose source material from all layers as though they were merged. Do not mark this check box if you want to choose source material from the current layer only.
Choose the Smart Blending option on the Tool Options palette.
You can also create a selection by using any of the selection tools before you activate the Object Remover tool.
You can deselect the selection by pressing Ctrl + D.
